bike wont start please help!!!!!
I just bought a 2003 f4i. It ran awesome when I picked it up everything was tip top. Then I did something really stupid. Well the guy I bought it from crimped a wire to the negative on the battery with a red crimper so I seen the red and automatically assumed it was the positive. As soon as I noticed the tender was pulling volts instead of issuing I pulled it off so maybe five seconds. Anyway. Long story short it ran fine before I put the charger on it. Now it wont do anything. The starter works lights all that. I can here the fuel pump turn on but there is no combustion at all in the motor, and ideas on what I can do? Is it a quick fix or an expensive one? I just hope I haven't toasted the ecu ecm . I have a friend thats going to bring his over and swap ecus to see, but until then anything else I can do or try?
Thanks alot. I checked all fuses, they are all good under the seat. Also the two relays under the rear faring one makes a clicking noise which I believe is for the fuel pump? The other one is silent. Im very new to any of this. Whats an rr? And any other thoughts? I live in Illinois is going to be nice very soon itching to ride but dont want to pay to take it to a repair shop:/
r/r is the regulator/rectifier. Hopefully you didn't fry it, though it is a possibility.
If you'd like to check in that direction, here's a few good links...
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
https://cbrforum.com/forum/f2-tech-9...-solved-27739/
Technical Resources - Resources for Electrical Systems on Motorcycles and ATVs - ElectroSport
Hope this helps, Ern
