Bike stalling
Old Jan 28, 2007 | 09:33 PM
determined's Avatar
Default Bike stalling
Hey guys, I have a 00 f4 with about 23k miles on it. Since it was raining and cold here for so long I didnt ride for about 2 months. The battery died. So I charged it and it worked fine for a few days I rode it Thursday. I start it Sunday and go to get gas when i finish filling up it wont start. A friend gives me a push and pop the clutch and it starts. Then when I am taking off in first I have to give it alot of gas and or it seems like its going to stall. Ride for about 5 miles to a friends house and its really starting to bog in first gear. Once I get up to speed it seems ok. Then when I get there I put it in nuetral while he runs inside and the bike dies. Push start it a few times and stalls again. Would the dead battery affect this? I am going to get a new batt tomorrow and charge it when the bike shop is open but what do you think is causing the stalling?
Old Jan 28, 2007 | 09:49 PM
importcarkid's Avatar
Default RE: Bike stalling
hmmmm sounds like the stator might be to blame
Old Jan 28, 2007 | 10:03 PM
determined's Avatar
But once the bike is running would that cause it to stall?
Old Jan 28, 2007 | 11:19 PM
Mstngdrew232's Avatar
Yes definatley, if you have a fuel injected engine it uses electronics for pretty much everything on the engine. Without your strator working properly you wont pull enough charge, and you're battery is the only thing powering your bike. And motorcycle batteries doesnt hold very much charge. I would pull it out and take it to a shop and have them test it to see if it is putting out enough charge before you go ahead and replace it. Electrical problems are never simple[:'(]. There could be more to this than we're seeing here.
Old Jan 28, 2007 | 11:44 PM
determined's Avatar
My bike is carburated not FI. So I am thinking it may be the carbs or fuel filter? Also which way is the fuel switch supposed to be coming out of the bottom of the fuel tank itshorizontal when i looked on it. I cant remember if its supposed to vertical or not?
Old Jan 29, 2007 | 12:51 AM
KingMushroom's Avatar
Check your choke over, make sure it isn't sticking.
You're battery could be **** too, but check it fluid levels to be sure you can't salvage it.
Old Jan 29, 2007 | 02:44 AM
ORIGINAL: determined
Oops, for some reason I thought yours was the F4i, idk why =X.
determined's Avatar
I checked the choke switch but where do I check its connection at the carb? Do I need to take fairings/tank off to check it?
Old Jan 29, 2007 | 04:53 PM
Yes. One or the other, tank is probably easiest.
Old Jan 30, 2007 | 02:48 AM
determined's Avatar
Update: picked up new charged battery and installed. Looked at petcock and it was turned off... how that happened I have no idea. Started bike warmed it up and tuned the idle speed and it runs like a champ. So, in short I think the idle had needed to be tuned for awhile anyways just kept getting worse then battery went dead and was shot. So both problems fixed and running strong with 23k and counting.
ko67
F2 Tech
Aug 1, 2011 05:04 PM
RBarker63
Apr 22, 2009 01:57 AM
stlstephens
Sep 3, 2008 10:06 PM
Sallen_71
Mar 31, 2008 04:11 PM
12stones
Jun 29, 2006 01:43 AM
