Bike shakes when i brake
Old Nov 12, 2005 | 11:13 PM
slowpoke's Avatar
Default RE: Bike shakes when i brake
To check the steering head bearings on my bike, I put it on the centerstand and use a scissors jack to lift the front engine pad. That lifts the front tire off the ground. Then I sit in front of the bike and grab the bottom of the front forks and push/pull. Any movement shows loose bearings. Then with the front wheel still off the ground, I turn the handlebars full left and right while listening and feeling for dry spots.
Yours doesn't have a centerstand so you have to figure out how to support the center of the bike without breaking any plastic and with the front wheel off the ground, but so the bike can't fall off. Some even hang the front of the bike from a strong garage beam. If you have to grease/change/tighten your bearings, you will need a service manual.
Old Nov 13, 2005 | 12:23 AM
05Tribal's Avatar
Limpz that is great! I actually laughed out loud at that one.
Old Nov 13, 2005 | 07:57 AM
Anubis's Avatar
Slowpoke see above post, saves you lifting the bike.
capuchin
Feb 23, 2009 09:58 AM
Bskinn77
Jan 26, 2009 09:17 PM
Bskinn77
Jan 26, 2009 04:46 PM
birde
Oct 14, 2006 01:59 AM
TwistedCBR
Apr 16, 2006 11:01 PM
