bike dies when past the mid point of throttle
Old May 23, 2007 | 08:41 PM
cit95's Avatar
Default bike dies when past the mid point of throttle
Hello everyone,
I own a 93 cbr600f2 and when I open the throttle past the mid point it bogs down like it ran out of gas. It will cut off unless I close the throttle a little. When the throttle is at thefirst half of the way open it works fine but anywhere past that point if doesn't work. I've drained the float bowls, drained the tank and put in new gas, checked the air filter, checked the fuel and vacuum lines for obstructions and damage. Hasanyone experienced this problem?Any advise would be greatly appreciated.
Old May 24, 2007 | 07:08 PM
flipsidef2's Avatar
Default RE: bike dies when past the mid point of throttle
i had the same problem, i ebnded up having a pinched fuel line and one of my air hoses that comes off the front of the bike was missing...
Old May 24, 2007 | 07:27 PM
143MYCBR's Avatar
Yeah, same thing here. Turned out, I forgot to flip the petcock switch from off to the on position!
Old May 24, 2007 | 08:12 PM
sloppyjones's Avatar
you might have some clogged up jets on you carb too, i suggest sea foam brand cleaner add a little to your tank and you are good to go, or running tooooooo rich in fuel.
Old May 24, 2007 | 09:40 PM
alekinci's Avatar
yea, i agree with jones. it could be the carbs or something with the fuel delivery.
switched
F2 Tech
24
Aug 16, 2017 09:18 PM
CBRF4600
Oct 5, 2013 04:59 PM
Survivalism
Jun 24, 2011 09:17 AM
Waymod
Aug 22, 2008 08:24 AM
viva_brasil
Apr 3, 2008 11:16 PM
