Best way to block off oil passage for CCT
If I wanted to install this tensioner what silicone sealant will work for blocking off that oil passage? I absolutely cannot have that leak or mess up in anyway..
mate what oil passage are you talking about? You mean the where the little key inserts to unwind/wind the tensioner or the paper seal which sits in between the tensioner and the engine? There'll be a nut which goes into the key hole anyway. You'd definitely need the paper gasket though. Although looking at it, you can easily fashion one on your own.
Nissantruckfreak
Sep 11, 2010 07:40 AM
