Best alarm system?
Old Sep 10, 2006 | 04:01 PM
Nessal's Avatar
Default Best alarm system?
So what do you guys think is the best alarm system out there right now? The best bang for the buck? The most expensive one?
Old Sep 10, 2006 | 05:40 PM
rjmech's Avatar
Default RE: Best alarm system?
I got the one from INTERNATRIX. It is sponsered on this site. It works very well and has pretty much the same features as the really expensive ones. 2 way paging and such. I like it for the money...
Old Sep 11, 2006 | 12:56 PM
DrDRFT's Avatar
Ive got scorpio i500 and I love it! The pager is small and beeps and virabrates has alot of functions! has shock and microwave and the other usual stuff. It also has a function where if someone did start it (impossible) and started to ride off and you couldn't get there in time to stop them wit a bat, you can press a button and it will kill the motor! Really good alarm(pager)!
Old Sep 11, 2006 | 03:27 PM
D2VW14_20's Avatar
LOJACK!!!!!!
Old Sep 13, 2006 | 12:27 AM
Nessal's Avatar
What is the difference between the scorpio and the internatrix besides that one is 1/3rd the cost of the other.
Old Sep 17, 2006 | 08:41 PM
rjmech's Avatar
Scorpio
Two-way FM security system that incorporates a handheld LCD transceiver that offers both pager and remote functions
Features long-range FM transceiver (up to 1/2 mile)
Compact design: main control module dimensions = 311/16†x 23/4†x 7/8â€
Dual-axis accelerometer for detecting impact/inclination
Sealed with polyurethane potting in accordance with OEM specifications
Built-in 120 dB multi-tone siren with soft chirp
Sensor violation display
Range and signal status display
Audible/vibrating alert
Smart battery safeguard with motorcycle battery condition display
Flashing lights with memory
Remote motorcycle finder/panic alarm
Clock with alarm
OPTIONAL FEATURES
Programmable perimeter sensor with warn-away feature detects motion around the bike, protecting saddlebags, luggage and accessories, and a built-in battery backup system that allows the pager to operate even if wires are cut or circumvented (included with PART #4020-0005, 4020-0006 and 4020-0034)
Ignition disable feature that allows the user to remotely cut off the engine in case of a hijack (included with PART #4020-0006)
TSR-6 impact-resistant/waterproof remote with rechargeable battery and charger (included with PART #4020-0034)
Optional OEM-style factory connector kits allow the alarm system to be integrated into the factory wiring without any cutting or splicing (sold separately)
Internatrix
Dimension: 4" x 2 3/8" x 1 1/8"
State of the Art: Microprocessor Design
Two-way FM Paging
Built in:Two level Piezo Vibration/Impact Transducer
Ignition Monitor: Panics, if key used or ignition is by-passed when alarm is armed
Bright LED Status Indicator: Blinks when Alarm is armed
Directional Signal Flashing - Flashes directional signals when alarming and confirming
Siren: High output 125db
Verbal Warning - verbal warning that Motorcycle is protected by an alarm system
Verbal Reminding- verbal reminder to arm alarm when the ignition is turned off
Automatic system reset- retains settings when power lost
Weatherproof
Antenna/ Transceiver
Dimension: 2 3/8" x 1 9/16" x 1/8"
Frequency: 433 MHZ
Certification: FCC
Perimeter Sensor
Dimension: 2 5/8" x 2 1/4" x 1/2"
Sensitivity: Adjustable
Frequency: 2.5GHZ
Remote Activate/de-activate
LCD Remote/Pager
Dimension: 2 1/4" x 1 1/4" x 5/8"
Display: LCD-Displays status of Motorcycle with icons
Arm/Disarm
Code Learning: 100Million codes
Low Battery Indication
Back Light
Anti-Hijacking
Panic
Arming Conformation
Additional Features
Silent Mode: Disables Siren, pages and verbal warning only.
Location Finder: Alarms Motorcycle to locate
Universal - designed for all 12VDC Motorcycles
Easy Installation
Other Specifications
Voltage: 9-15 VDC
Static Current: 20 ma.
Warranty: 1 Yr. Limited
Mfg. Cert.: ISO 9000
Old Sep 18, 2006 | 12:21 AM
spdrmns's Avatar
BEST ALARM SYSTEM IS COMPRENSIVE on insurance ! an alarm system isnt going to stop someone from stealing your bike if there smart, it will stop the idiot gangbangers but not the proffessionals .... just get comprensive and you dont have to worry!
Old Sep 18, 2006 | 12:47 AM
D2VW14_20's Avatar
You still have to worry. The insuance companies arent the easiest people to deal with and there are stipulations to it
Old Sep 18, 2006 | 07:46 PM
rjmech's Avatar
True the alarm will not stop anyone but it would be more noticable to the public if the bike was being stolen. Also, some insurance companys give a pretty good discount for haveing a permanantly installed alarm system.
mbison83
F4i - Wanted
Aug 1, 2011 07:23 PM
92seca2
Jun 13, 2009 02:55 PM
TXDISABLEDVET
Sep 1, 2007 10:21 AM
doncollins
Dec 5, 2005 09:48 AM
