battery or alternator?
Its much more likely to be the reg/rec failing than the stator. stators usually only fail after a bad drop on the left side.
But its no use guessing you need to do all the tests with a multimeter.
As well as the test already mentioned for the stator you should also check each wire to earth for continuity.
There should be NO continuity.
I would also check the voltage from each wire while the bike is running at 5k they should all show the same voltage, just remember to set your meter to ac and unplug the connector or you will get false readings.
do they have rr manuals?
scratch that. i just found the manual post.
thanks anyways
I tried to follow the instructions posted on this site to check whether its my charging system or battery that seems to be faulty. But its not very useful since there is a missing step (step 4). So I was wondering if someone can provide me a step by step procedure for me to follow. Thanks in advance.
1. measure the voltage at the battery with the bike off. It should read above 12 volts. Start the bike, let it warm up. Turn on high beams and bring the revs up to 4,000 rpms. The voltage now should be above 14 volts, near 15. If the voltage has dropped or not increased, the battery is not being charged by the charging system. If the voltage increases to an acceptable range,(13-15.5) then the bike is charging and that is not where your problem is. At that point, you could look into your battery or an external draw on the battery.
If the bike has been determined to not be charging, with the bike not running, remove the plug from the rectifier and measure resistance in oms across the three same colored wires. 1 and 2, 2 and 3, 1 and 3. The resistance should not be greater than 1.0 ohm. Also, take those same wires and one by one, place the hot lead of the ohm reader to the wire, and the ground to the ground of at the battery. Again, there should not be more than 1.0 ohm of resistance. if there is in either case, the stator has grounded and will need to be changed.
Also, since your going to be there. Make sure all of the pins are secure inside the plug. Sometimes, the pins will work their way out and even though the plugs are together, the wires internally are not making contact. Just something to look at while your there.
But, from what you've already posted, I would lean towards it not charging and needing the stator checked.
