basic ground question
Old 08-17-2009, 06:54 AM
Cytotek's Avatar
Default basic ground question
okay im a new member hi guys (already have a post in the f3 section)
i have had my f3 for about a month now and the other day i noticed theres what appears to be a ground wire attached to the frame where the steering column i guess you would call it goes through to the left of the fuse box on the frame, its just clipped and i would like to know where it goes so i can fix it, ill try and get a picture of necessary but its right in front of where the vin tag is
Old 08-18-2009, 11:30 AM
mikey49's Avatar
What color is the wire?
Old 08-19-2009, 03:32 AM
Cytotek's Avatar
brown tanish
Old 08-19-2009, 08:39 AM
johnnyx's Avatar
Pictures would be immensely helpful here. Show where it is coming from, and going to.
As it stands, your fuse box does not have a straight brown wire coming from it by default, so it has to be something a PO installed. . .
Also, how do you know it's ground? Did you test it for voltage?
Old 08-20-2009, 12:36 AM
mikey49's Avatar
Yes, pictures might be helpful. Look for somthing that either is an add on item or something that isn't working. Could that color be blue/brown? I certainly would not ground it until you trace it back to what ever it is connected to.
mikey
Old 08-20-2009, 02:29 AM
Cytotek's Avatar
i say ground because its attached to a bolt/screw on the frame... its only about 3 inch's long i forgot to get a picture ill get 1 tomorrow, but im 90% sure its a ground because 1 its connected to the frame and 2 theres no other wires around and my bike doesnt seem like anything isnt working
Old 08-24-2009, 10:11 AM
johnnyx's Avatar
Yep. ground. The absolute quickest way is to trace the wire and see where it goes. Everything else would be hoping and guessing.
this guy
11-23-2013 10:15 AM
NeedHracing
11-03-2009 03:50 PM
Kawlison
10-16-2007 12:07 PM
cottlefish
10-12-2006 02:38 AM
wiz
04-13-2006 01:09 AM
Quick Reply: basic ground question
