Bank angle sensor HELP
Old Mar 13, 2006 | 04:15 PM
elkakandkss's Avatar
Default Bank angle sensor HELP
Ok here's the thing I have a go-kart witha 02 600 f4i on it. I need to know what color wires or how to buy pass the tip over sensor. On the wiring harness I dont have the front harness, so there for at the plug where you plug the front harness in thats where I need to loop it. what 2 wires do I need to jump. I had It jumped it befor but the dam wires came out and I for got the colors. one other thing for the fuel it is an intake fuel pump. do they make an out side fuel pump, do you know what is the stock fuel pressure. PLEASE ANY HELP WOULD BE GREAT. Thanks Jason
Old Mar 13, 2006 | 05:09 PM
wantafastf4i's Avatar
Default RE: Bank angle sensor HELP
I believe its the top wires on each side of the connector.As in the top left and the top right. Dont remember the colors but thats where i jumped mine for a while.
Old Mar 13, 2006 | 05:16 PM
At the big gray plug? And can I just cut the wires and splice them together?
Old Mar 13, 2006 | 09:23 PM
thirdgenlxi's Avatar
Ironmang
The bank angle sensor is a black 3 pin plug, and the wires should be G, W/Bl, and R/W. The green is the ground that runs through the whole bike, the white/blue goes to the kill switch and a 10A fuse in the fusebox, and the red/white goes to the engine stop relay
Old Mar 15, 2006 | 01:39 PM
Now that black plug, plugs into the front harness and than the front harness plugs intothe mid harness. Where it plugs into the mid harness are the wire colors the same.
Old Mar 15, 2006 | 09:18 PM
Ironmang
Yep wire colors stay the same throughout from one end to the other
Old Mar 16, 2006 | 03:38 AM
sorry didnt realize i was in this thread. Yes the big grey plug is the one im talking about. I will look tomorrow if i can get at the wiring and tell ya but the grey plug is the one im talking about. I bypassed mine for quite some time with a paperclip. All you do is put one end in the first wires' pin and the other end in the second wires pin. Voila you are bypassing the bank angle and the bike will start upside down if ya want Hope this helps and i'll let you know tomorrow what exactly i bypassed.
Old Mar 17, 2006 | 02:45 PM
That would be helpfull. Thanks
maksim
Dec 7, 2014 12:33 AM
roaddog
Jul 18, 2011 04:28 PM
Phatcbr
Oct 19, 2010 09:37 AM
itsgroll
May 11, 2010 09:32 PM
900rr_Guy
Mar 7, 2007 01:05 PM
