Bank angle sensor HELP
Ok here's the thing I have a go-kart witha 02 600 f4i on it. I need to know what color wires or how to buy pass the tip over sensor. On the wiring harness I dont have the front harness, so there for at the plug where you plug the front harness in thats where I need to loop it. what 2 wires do I need to jump. I had It jumped it befor but the dam wires came out and I for got the colors. one other thing for the fuel it is an intake fuel pump. do they make an out side fuel pump, do you know what is the stock fuel pressure. PLEASE ANY HELP WOULD BE GREAT. Thanks Jason
The bank angle sensor is a black 3 pin plug, and the wires should be G, W/Bl, and R/W. The green is the ground that runs through the whole bike, the white/blue goes to the kill switch and a 10A fuse in the fusebox, and the red/white goes to the engine stop relay
sorry didnt realize i was in this thread. Yes the big grey plug is the one im talking about. I will look tomorrow if i can get at the wiring and tell ya but the grey plug is the one im talking about. I bypassed mine for quite some time with a paperclip. All you do is put one end in the first wires' pin and the other end in the second wires pin. Voila you are bypassing the bank angle and the bike will start upside down if ya want
Hope this helps and i'll let you know tomorrow what exactly i bypassed.
