bank angle sensor? 2007 cbr1000rr
Old Jun 29, 2011 | 06:03 PM
roaddog's Avatar
Default bank angle sensor? 2007 cbr1000rr
dudes my bike was stolen recovered four months later a wreck it was laid down one side a mess. stripped off old parts bought new ones in=gnition exhaust you know but im not getting any gas to the fuel pump.. bank angle sensor? thats what im being told can it be reset do i need to replace it ? where do i find the f in thing need help
donovanscott@sbcglobal.net
Old Jun 30, 2011 | 10:43 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
The BAS is located in the center of the nose fairing. You can test to see if that is the problem by shorting the two outer wires together (leave the center wire alone). That will bypass the BAS and you can look for another problem if it still won't start.
Old Jun 30, 2011 | 10:47 AM
toptaz1000rr's Avatar
what rodi said...
there is no way to reset it other than stand the bike up ..
also make sure you mounted it the right way ... flat side up...
Old Jul 4, 2011 | 07:14 PM
roaddog's Avatar
this sensor connects to where the ignition harness the headlights or does it just sit in the nose fairing the bike was stolen and crashed i didnt see any sensor in what was left of the nose if i go buy one where the heck does it plug in?
Old Jul 4, 2011 | 07:57 PM
plugs in to the headlight /guage harness
its usually a small green plug..
bolts in between the headlights... on the headlight fairing
maksim
Dec 7, 2014 12:33 AM
itsgroll
May 11, 2010 09:32 PM
900rr_Guy
Mar 7, 2007 01:05 PM
mhamilton
Aug 24, 2006 12:31 PM
elkakandkss
Mar 17, 2006 02:45 PM
