Bad Throttle Lag need help.
Old Jun 18, 2008 | 02:56 PM
walkeryan's Avatar
Default Bad Throttle Lag need help.
I have an '02 CBR f4i I've been riding for 3 months now, just the past couple weeks I've noticed in first gear at take off when I gun it it sputters, acts like it doesn't wanna go anywhere, then a few seconds later takes off. I've changed the plugs, the airfilter looks good and I'm to my wits end. I've taken it to two shops and they both said "motor runs fine" but they are idiots because I know it wasn't like that when I bought it. The F1 light has also been comming on I believe one error was the MAP sensor but all connections look good. A friend said to check the vacuum hoses and make sure they aren't bad, as well as check the fuel filter. I'll do this tonight. The engine revvs up fine without a load on it (Clutch held in) but just when its under 3k rpm its sputters. Hope I've given enough info , thanks for the help in advance guys.
Old Jun 21, 2008 | 05:21 PM
HondaTech68's Avatar
Default RE: Bad Throttle Lag need help.
well if your FI light came on it popped a code and something is going on with it sounds like the shop you go to is full of idiots without knowing exactly what code it is I can't really help you there is a connector under the seat 2 pin that needs to be jumped then you have to count the flashes of the FI light fast flashes count as 1 a 2 second flash counts as a 10 so if you have one long flash and three fast you have a 13 code see if you can tell me exactly wha code it is keep in mind you could have multiple codes so you have to watch the pattern
darikfrye91
F2 Tech
Jan 16, 2012 10:55 PM
cbr6rider
Apr 20, 2011 08:57 AM
Gacho
F2 Tech
Apr 6, 2011 04:13 PM
zellster
Sep 29, 2010 02:42 AM
