bad starter? about 1ohm resistance
Old Oct 24, 2011 | 06:47 PM
segraves1's Avatar
Default bad starter? about 1ohm resistance
I went to put my starter together today (I powder coated the case black to match the motor) and it's shorting out. I pulled it back apart and with the armature out, there is no short. Put the armature back in, I get about 1ohm of resistance (positive terminal to starter case). Pulled the armature back out and tested the resistance across the armature pads (where the brushes run) and I get anywhere from 1-4 ohms resistance.
Ideas?
Old Oct 24, 2011 | 07:41 PM
segraves1's Avatar
never mind... turns out my bench top power supply doesn't have enough amps to turn these little starters. Grabbed a car battery and the motor zipped to life.
Old Oct 24, 2011 | 08:39 PM
i was going to say, those readings sound about right. I'll bet that starter looks really good.
Old Oct 24, 2011 | 08:49 PM
segraves1's Avatar
Still need to get the cylinder head coated but I'm happy with the results thus far. Since I'm going naked, I didn't want anything (other than the stainless bolts) to "show".
Attached Thumbnails bad starter? about 1ohm resistance-img_0832.jpg   bad starter? about 1ohm resistance-img_0833.jpg
Old Oct 25, 2011 | 10:32 PM
OMG! It looks great! Very nice work.
Al slack
Apr 30, 2013 06:48 PM
PILGRIMSUPPORTER
Apr 4, 2012 05:08 PM
pcicrich
Nov 3, 2010 06:36 PM
pcicrich
Nov 3, 2010 06:26 PM
Turbochops
Feb 12, 2008 07:07 PM
