Bad Ballast or HID Bulb?
Old Nov 25, 2012 | 08:51 PM
cschew's Avatar
Default Bad Ballast or HID Bulb?
Both my my HID bulbs don't work. I've had these for about 6 months. I ordered them from DDM tuning.
I do not know if the ballast or bulbs have gone bad. When I start the engine, the HID bulbs flicker, but do not turn on. At first I thought it was a wiring issue, but then I put in my halogen bulbs and they work fine.
Is there a way to tell if the ballast or HID bulbs are bad?
Old Nov 25, 2012 | 08:54 PM
CBR Knight's Avatar
If they flicker and go out I would bet it is the lamps instead of the ballasts. I have seen where the glass will crack and prevent the lamp from fully igniting.
Old Nov 25, 2012 | 09:22 PM
CorruptFile's Avatar
June 2013 ROTM
More than likely the ballast. The bulbs are usually work or don't work. DDM supposedly has a lifetime warranty
Old Nov 25, 2012 | 09:34 PM
cschew's Avatar
What lamps? You mean the bulbs? They do not appear to have any cracks in them.
Old Nov 25, 2012 | 09:35 PM
cschew's Avatar
The high beam stopped working first. And then the low beam stopped working like half an hour later after riding.
So, I'm thinking its the ballast too..... But I do not know how to confirm this.
Old Nov 25, 2012 | 10:15 PM
June 2013 ROTM
Not sure. HIDs work by arcing in a gas. If the glass is broken the gas escapes and there should be no light whatsoever.
You could either test it with a known good bulb - or a known good ballast. Shouldn't matter though, DDM should replace the kit.
Old Nov 26, 2012 | 12:36 PM
letsride's Avatar
Did you touch the bulb when you were installing them? Oil from your fingers could cause the bulbs to fail.
Old Nov 26, 2012 | 02:01 PM
cschew's Avatar
Yea i'm emaling ddm tuning right now. They told me to do a direct battery test and it confirms that its something wrong with the ballast/bulb, not my harness. I'm just waiting on them to respond back now.
Nope, I wore gloves while installing the HIDs.
stretch_the_apex
Sep 3, 2010 09:30 PM
bigguysmallbike
Jun 9, 2009 04:36 PM
Dan2Ghost
Aug 29, 2008 04:09 PM
954RR RH
Aug 4, 2008 11:59 PM
