RE: average oil change cost?
i just changed my oil today. 4 quarts of Honda CN4 oil for 13 dollars and an oil filter. everything for 27 dollars and change. just FYI
David |
I've used the Mobil 1 MC oil before. Got better results with the Motul though. Make sure you don't use Mobil 1 10w-30.
ORIGINAL: IronFox honda gn4 oil costs about $15 and the filter for mines about $7. Im thinkin about using mobil1 anyone use it? |
Yeah i just did one it costs about thirty bucks. i use 20 50w oil i dont like noise when i used 10 30w the first start up was a little noise but to each his own. Make sure you use motorcycle oil cause car type oil gets bubbles and air pockets or foam. and the tolerences are so close that that could cause trouble. I use honda oil from the dealer. Hope i could help
You shouldn't switch back to regular oil after using synthetic. syn makes seals swell just a bit and could cause a leak if you switch back and fourth.
ORIGINAL: ImmaSquashYou ORIGINAL: shraz that is a bunch of lies you can go from synthetic to non and vice versa easily |
ORIGINAL: ImmaSquashYou ORIGINAL: shraz that is a bunch of lies you can go from synthetic to non and vice versa easily what is the difference oil is oil only thing syntthetic dose is lasts longer with out breaking down . all this you can not change back and forth is bull **** show me one case of an engine blowing up from switching???? that is crap the oil companys put out to keep you buying there expensive stuff |
P B... 36$, schaffer semi syn, incl. wix gold filter. find out about oil yourself, by learning what additives in the different packages do... I don't care what anyone says... there IS a differences, in oil and additive packages. Boron, Phosphorus flashpoints, viscosity loss after hot, and about 20+ other measured considerations, learn ,learn, learn. then make a wise choice. Clean and free, only smoke'n harleys!!!!!!!! Ripp'n
