anyone change bearings? FLORIDA
Old Apr 28, 2006 | 09:10 PM
TwistedCBR's Avatar
Default anyone change bearings? FLORIDA
I am debating between it being the bearings or the caliper and i wanna change the bearings in the rear tire...how in the WORLD is this done and anyone in FLORIDA that would be so kind as to lend a hand??
Old Apr 28, 2006 | 10:04 PM
mysteereusone's Avatar
Default RE: anyone change bearings? FLORIDA
Get yourself a Haynes repair manual and it should walk you right throught it. You will have to buy a long punch to drive those bearings out. When you get them out save them so you can get the part numbers off of them. If you do your wheel you should replace the bearing in your hub also while it is apart.
Old May 4, 2006 | 06:21 PM
TwistedCBR's Avatar
see all this is german to me
Old May 4, 2006 | 10:10 PM
kustom98f3's Avatar
You have to get the rear tire off and take off the rotor and sprocket hub. The bearings are just pressed into the wheel along with the seals, same goes for the hub. Your best bet is to use a press to get them out but it can be done using a hammer and some sockets/extensions to punch them out. Putting them back in is the reverse operation. Just make sure that your socket is on the metal ring of the bearing and not the side casing when putting them back in or you will destroy the bearing.
89HurricaneF1
May 7, 2012 09:52 PM
blacken77
Feb 24, 2012 06:14 PM
xp3085
F2 Tech
Jun 20, 2011 09:10 PM
michealparks
Feb 10, 2010 12:16 PM
mr.nick705
Nov 6, 2009 01:42 PM
