Any Insight!!!!!!!!!!!!!!
Old Aug 5, 2007 | 10:23 PM
Hueyguy626's Avatar
Default Any Insight!!!!!!!!!!!!!!
Well i bought a used 52,000 mile decent shape 929rr for $1,300 ran when i picked it up and the guy ran it out of gass in-front of me and when we opened up, the tank it smelled like varnish so i know we got bad gas. got it home pulled out the tank and drained it, pulled air box and plugs. checked gap .32 right. cleaned air filter. and plugs, new high grade fuel and injector cleaner installed tank and cant find 1 hose for it? dont know if it was not there or if in the excitement of it all, just dont know but it is not the main fuel line. It is not the two smaller lines it is the biggest of the lines besides the fuel line and not the one that comes off of the 90 deg. tube it is a straight down tube about an inch long? any ways now it wont fire. so i'm thinking clogged filter or fuel rail or injectors. also second gear slips but it's not the clutch was told it's some kind of fork in the tranny and it would be an 1,000 + job to do. any insight would be great.
Old Aug 6, 2007 | 12:33 PM
Robert82's Avatar
Default RE: Any Insight!!!!!!!!!!!!!!
the two lines are i believe breathers, you will definitly have to clean out fuel system. The shift forks costs about 60 - 80 bucks and you can do it your self very easily in about 2 hours.www.bikebandit.com has all the OEM parts you need. i did my shift fork and it 2 hours and cost 100 bucks, dam synthedic oil.........
Old Aug 6, 2007 | 12:39 PM
Tahoe SC's Avatar
you'll need to pull off the tank again from the fuel filter. i believe it's in the tank.
Old Aug 6, 2007 | 01:24 PM
Nauree's Avatar
seafoam seafoam seafoam pour it all over the bike. in your exhaust and in your sparkplugs. if you can dip your whole bike in some seafoam.
uizdustin
Aug 20, 2014 09:32 PM
FourSix
Sep 15, 2010 12:28 AM
infinitcash
Jan 9, 2009 08:52 PM
abdelito14
May 12, 2008 10:22 PM
optlo
Jul 25, 2007 09:35 PM
