any ideas to make it run
Old Jan 12, 2012 | 01:42 AM
cascenico's Avatar
Default any ideas to make it run
I took to the shop to make it run and I get a call that bike doesn't have Enough compression to run..and the only to run is to rebuild the engine... The question is there anyway to beside rebuild it ... Or is it easy to rebuild the engine
Old Jan 13, 2012 | 08:40 AM
Conrice's Avatar
you MUST have compression to get it to run. you need air, fuel, compression, and spark to make a motor run. without those 4 things - it won't run.
rebuilds are on the higher end of the spectrum as far as amount of mechanical ability needed and are VERY expensive.
you're better off buying a used motor off of ebay and swaping it.
Old Jan 13, 2012 | 09:52 AM
Kuroshio's Avatar
+1 new-to-you motor. Depending on your bike, there might be plenty availible
Old Jan 13, 2012 | 10:55 AM
Conrice's Avatar
and sell your ****ed up motor to someone for real cheap that likes rebuilding them
FLYOU
Sep 16, 2008 02:53 PM
f4iguy8804
Jun 8, 2007 04:10 PM
JBaz
Nov 10, 2006 05:10 PM
SEAN_VANCE
Oct 31, 2006 05:39 PM
