any ideas to make it run
I took to the shop to make it run and I get a call that bike doesn't have Enough compression to run..and the only to run is to rebuild the engine... The question is there anyway to beside rebuild it ... Or is it easy to rebuild the engine
you MUST have compression to get it to run. you need air, fuel, compression, and spark to make a motor run. without those 4 things - it won't run.
rebuilds are on the higher end of the spectrum as far as amount of mechanical ability needed and are VERY expensive.
you're better off buying a used motor off of ebay and swaping it.
FLYOU
Sep 16, 2008 02:53 PM
felk27t
Jul 31, 2007 11:08 PM
