ANY ADVICE WOULD HELP OUT!
I HAVE A PAIR OF FORKS ON MY 04 F4I THAT ARE TWISTED PRETTY GOOD, I HAVE A NEW SET ON THE WAY
SO MY QUESTION IS ARE THERE ANY TIPS OR ADVICE YOU GUYS CAN PART WITH ON INSTALLING THE FORKS?
IM A CAR TECH SO I THINK ILL BE OK BUT IF THERE ARE ANY TRICKS TO THE INSTALL OR ANYTHING THAT MAY PROVE HELPFUL
I WOULD REALLY APPRECIATE ANY ADVICE
THANKS ALOT GUYS
RIDE SAFE
THANKS ALOT GUYS
RIDE SAFE
RE: ANY ADVICE WOULD HELP OUT!
ORIGINAL: radvoem
THANKS ALOT GUYS
RIDE SAFE
THANKS ALOT GUYS
RIDE SAFE
1) Make sure both forks are the same height in the triple clamp
2) tighten everything but the fork pinch bolts at the axle
3) Grab the front brake and compress the forks a few times to center the forks on the axle
4) Before you tighten the pinch bolts check the gap on both calipers between the disc and the caliper to make sure there not rubbing
Hey Radvoem,
Here are those torque specs sorry I'm late with them been buys last few days
Handle bar pinch bolts 17 ft/lbs
Top triple clamp bolts 17 ft/lbs
Lower Triple Clamp Bolts 29 ft/lbs
Axle Bolt 43 ft/lbs
Axle Pinch bolts 16 ft/lbs
Caliper Bolts 22 ft/lbs with a medium locktight
Axle Bolt 43 ft/lbs
its cool man im layed up in a cast from a low side from some gravel, but its coming off soon and i will get to replacing the twisted forks
again, thanks for taking the time to look up the specs! i know how bust techs can be, im a car tech myself
ok time to drift of into a nice game of moto gp 07
ride safe man
radvoem
ride safe man
radvoem
