Anodizing
Old May 19, 2011 | 04:35 AM
mike.bucci's Avatar
Default Anodizing
So I've been looking into anodizing for the past several hours and came across some DIY techniques, some previously posted here, some not. I plan on givin it a shot this afternoon with some old aluminum pieces like the barrel of a paintball gun. I'll definately repost as to how it comes out and what I end up anodizing on my bike.
Old May 21, 2011 | 02:24 PM
Honda125 358's Avatar
I had a really good how to on it a while ago, I wish I could find it again
Old May 21, 2011 | 02:39 PM
Kuroshio's Avatar
Moved to General Tech. How To is for posts with... um, How To
Old Jun 11, 2011 | 10:15 PM
segraves1's Avatar
What ever happened to this?
Old Jun 12, 2011 | 12:32 AM
mike.bucci's Avatar
haha sorry man. forgot to update. the process worked ... but with too much trial and error. it ended up becoming too much of an expense to continue. Had gotten the exact colors we wanted a few times and tried to perfect it, but ran into problems like to much dyed water boiling out and creating dye rings on the pieces and also the "setting" bath removing the dye (exactly the opposite of what it was supposed to do according to the directions). I may try again at a later date once i have a steady income. Once i can figure out the best temperatures and such for all the different baths, water:acid ratio, and other factors, I will write a fully detailed how to and try to eliminate as many "gray areas" as possible.
Old Jun 12, 2011 | 01:20 PM
segraves1's Avatar
After I read your reply, I went and did a little digging of my own on the net. Seems the general consensus that when the color doesn't stick, the anode (or cathode... the negative side...always get them backwards) wasn't pure. One guy said to use 6061 (I think that's what it was) aluminum. Other thing the guy said was a solid 10amps supply is needed (he used a big battery charger on 10amp setting).
Just some info. I'm really tempted to try it since all the placed in Phoenix want a minimum of $150-$200 to do anything.
Old Nov 10, 2011 | 09:01 PM
Rainychicken's Avatar
I've been trying to anno for the past few days and I cannot get the dye to stick at all.. My cathode is made out of an aluminum sheet I got at menards so Im assuming/hopeing thats pure enough. Also my battery charger says its a 6 amp so maybe its to small? Ive left the pieces in there as long as 2 hours and no luck.
Old Nov 11, 2011 | 10:35 AM
Jim T's Avatar
If you havn't already try caswell.com. They sell and support plating products and they also have a forum. I have their zinc set up and a controller for accurate volts and amps it works pretty well too. They also have a for sale section for used products.
Old Nov 11, 2011 | 10:49 AM
mike.bucci's Avatar
yea its not easy to perfect. there a lot of factors that need to be exact in order for this to work. i will probably try it again but not any time soon.
jjsmi
May 27, 2008 07:22 PM
PYRO929
Jan 25, 2008 04:36 PM
hopkinslax12
TRG Coating
Oct 19, 2006 10:15 PM
BBLineBacker81
Jul 23, 2006 03:07 AM
