Analog to Digital Gauges?
Old Sep 11, 2008 | 06:56 PM
rrasco's Avatar
Default Analog to Digital Gauges?
I am doing my front end swap and realize that my bike currently has analog gauges and speedo. What I want to know is, how hard, if possible, is it to convert to digital gauges, say, those from a 600rr or similar? I know some things like the fuel gauge will not work since I don't have one at all, but how about everything else?
Old Sep 11, 2008 | 10:51 PM
TK954RR's Avatar
Jan 2009 ROTM
Default RE: Analog to Digital Gauges?
I dont know Rrasco, the speedo is driven off of a speed sensor in the trans, and the tach runs off of the ECM and combi sensor. The tach maybe you could get to work splicing into an ignition source, similar to what you would do on a car. The speedo though im not sure how you could get a reading, since im pretty sure yours runs off a cable instead of sensor (however i could be wrong on that). If it is off a sensor you can probably get it to work.
Old Sep 11, 2008 | 11:28 PM
rrasco's Avatar
I was doing some reading and have *read* that you can use f4i gauges, a speedo healer, and the sensor off of a gsxr. The temp gauge is supposed to work if you get the f4i sensor too. That is my main concern, is the whole cable driven speedo.
http://cbrworld.net/forums/permalink...ad.aspx#224864
Old Sep 12, 2008 | 12:15 AM
TK954RR's Avatar
Jan 2009 ROTM
I can definatly see the temp not being an issue, it just reads amperage as it gets hotter, the amps change, so you just need to get the right signals sent to the gauge. I didnt know that the gsxr signal was taken off of the balance shaft. I always thought the old speedo was gear driven and the new style used a reluctor ring for a reading. I could very easily be wrong on that count. Im not a bike guru at all, im a car junkie with some mechanical ability . i Guess i would send the guy who did the conversion an emal and see what info you can get from him, see if the transmission in yours is the same setup. If it will read off the balance shaft, pop out your cable and stick a light in there and see if you have clear access for the sensor to drop in, and if you can bolt it down, or have room to drill and tap a mounting hole that wont interfere with any internals. Usually with the right amount of $, time, and patience anything can be done, just whether its worth it or not.
Old Sep 12, 2008 | 09:26 AM
rrasco's Avatar
What is the balance shaft? When it comes to speedos, I know ZERO! Also, do you have any clue what temp sensor I would need? I see two on ebay, one is an 'air sensor' that goes in the airbox. The other is listed as a 'temp switch'.
http://shop.ebay.com/items/?_nkw=f4i...sid=m270.l1313
Old Sep 12, 2008 | 10:01 PM
Quickslick444's Avatar
Why dont you look at some universal magnetic speedos. Koso is a good brand.
Old Sep 13, 2008 | 07:21 PM
rrasco's Avatar
Price. I can get a set of F4i or RR gauges for around $100, a nice pair of aftermarket gauges would run $300+. Thanks though, they do make some nice ones. The only other ones I had seen were by Veypor.
Old Sep 13, 2008 | 08:58 PM
Nauree's Avatar
**** Digital Gauge is what I read.
Old Sep 14, 2008 | 02:10 AM
zerochickenstrips's Avatar
I've installed a Koso gauge on my F2 and it works wonderfully. Very simple without trying to mix and match parts. It comes with everything you need.
ZachLeon
Mar 24, 2011 03:26 PM
Thaibiker85
Sep 23, 2009 01:38 AM
mitchedwards81
Mar 15, 2007 03:00 AM
mitchedwards81
Mar 13, 2007 10:55 PM
one2imagin
Mar 17, 2006 09:53 PM
