altered trans gear
Old Nov 4, 2010 | 06:38 PM
montoney2's Avatar
Default altered trans gear
Anyone know how possible it is to replace, alter or have a gear made to make 6th gear higher? like the torque with the bigger sprocket but hate running 6500rpm on the highway.....
Old Nov 4, 2010 | 06:42 PM
NateDieselF4i's Avatar
Well i'm sure you have options. I would try posting up in the F4i section, or whichever section pertains to your specific bike.
And ah... welcome? Where in Va are you.
Old Nov 5, 2010 | 08:40 AM
Michaud85's Avatar
so your bike runs fine, you just dont like running at 6500 on the highway.... i think its much better for you to get used to that rather that alter the transmission on your bike. your bike can run 6500 all day long and your not gonna get much better mpg if your trying to get down to like 5500
Old Nov 5, 2010 | 12:07 PM
montoney2's Avatar
Front Royal, Va. The 900 engine isn't ah high rpm *** a f3. Its working pretty hard at 6500-7000. I commute to work and want to take me bike sometimes. The engines getting rebuilt now, I don't want to trash it. A few houndred for a gears good piece of mind.
Old Nov 5, 2010 | 12:14 PM
montoney2's Avatar
I would like to run my 55t sprocket and be able to run like 3500 on the highway. Maybe its crazy but....I'm redoing this bike this winter and I want it the way I want it.
Old Nov 5, 2010 | 12:18 PM
montoney2's Avatar
Don't know how to post only 900 section..... plus maybe other house have had one since its a F3/900 hybrid and both bikes have been around a while. _
Old Nov 5, 2010 | 02:01 PM
Sprock's Avatar
CLICK HERE
Top Left corner click "New Thread" ...........unless a recent thread already covers the
question or discussion, in that case perform a "reply" / post
Old Nov 5, 2010 | 08:10 PM
montoney2's Avatar
thanks
Old Nov 6, 2010 | 03:12 PM
thrasher572's Avatar
It might be less expensive to pick up a second drive hub for the rear wheel... and run a "stock" sized spocket on it. Then on stunt days drop the axel and flip hubs...just a thought. About the only issue with this will be the length of the chain...so stock may be too small, but closer to stock may work.
Old Nov 7, 2010 | 10:36 AM
Michaud85's Avatar
after reading the thread again i now see your dilemma.
you could jeryy rig a rear sprocket gear changing system that could go between stock rear size and your new larger sprocket...... not reccomended unless your an engineer of some sort. this would be the best solution to your problem
bring the 6th gear from your tranny to a machinist and have him make one of a different size... gonna cost money
im sure you can get a gear made but ull have to go into the tranny get it out and bring it to a machinist and he can make you one that will make 6 run lower rpms. that will cost alot of money
or do what someone above said and just swap the sprockets on stunt days (if you are a stunter) and riding days.
this problem is why alot of stunters have a stunt bike and a riding bike
Flatl1ne
Oct 2, 2010 10:43 AM
twodown
Aug 20, 2009 06:59 PM
stoneguy1037
Aug 16, 2008 07:38 AM
cuathetop
Jun 27, 2006 02:36 PM
