99 Honda cbr900rr
Old 04-05-2018, 09:00 PM
tentacleslap's Avatar
Oh wait. It works with one battery but not the other? That tells me that you've got a bad battery, or maybe loose terminal connections
Old 04-05-2018, 09:01 PM
Rexx900's Avatar
Originally Posted by tentacleslap
To check the main fuse, you just need to pull it out and check continuity. I don't know your exact bike so you might need to look it up to find the exact location
If the bike turns over but won't fire, you will need to confirm spark. If you're experienced, there's an easy trick where you pull the plug, leave it connected to the ignition wires, ground it to the case, and turn the bike, watching for a spark. For a beginner I'd recommend an inline tester to make the job easier. Either way, I would start by downloading the manual and familiarizing yourself with the ignition system troubleshooting
my assumption is the plugs I'll check for the tester that lights up thank you very much your help is truly appreciated
MARTINEZ
04-07-2008 12:23 PM
troyalexand
11-23-2005 09:39 AM
Quick Reply: 99 Honda cbr900rr
