99 CBR600 Green Fluid Leakage
Hi, just came back from a morning ride that lasted about an hour or so. It was my first time out riding on my own since I had got my license
Anyways, I was practicing my work route today. So when I got to work, I got off the bike for a bit to stretch and stuff for a minute. (left the bike running)
I'm all done, ready to get back on, and I notice a green fluid (antifreeze I'm assuming?) dripping from the very bottom of my bike. Not an extremely fast green fluid gushing everywhere but a drip-drip-drip kind of leak. I'm like.. whatever, gotta get home so I hop back on and ride back no problem whatsoever.
I remember a month or so ago, when I lowsided at like 5mph, the green stuff started leaking right after I fell and it continued to leak a tiny bit every time I'd start the bike and let it idle. This is probably a stupid question, but what should I do/check/fix/etc?
Thanks.
Thanks.
You might first try to determine if it is merely running out of the overflow tube. Is the reservoir low on fluid?
If it's not coming out of the overflow tube wipe off or wash off what's there and see if you can narrow down the source when it leaks some more. It might be a loose hose clamp or something minor.
Practicing your work route?
Oh and by practicing my work route I mean, since it was my first time going out alone since I got my license last weekend, I went to work and back for practice.
Good luck with your commute and I hope you get your antifreeze leak problem resolved.
Pull your R side fairing off & do thorough inspections.
I'd imagine that a 1999's radiator hoses are probably starting to weaken (if not well there already). Weakening radiator hoses = leakage. As mentioned, check you clamps & tighten, & replace radiator hoses if necessary. You don't want a ruptured radiator house spraying all over your leg(s). Trust me on that (not to mention an overheated engine).
Also, thoroughly inspect the overflow bottle for cracks. Yes, you need to take it off & inspect the backside as well. If your heat-shield (rubber piece) isn't on properly, or at all, the bottle could melt enough in one spot to open up a tiny hole & start leaking. Again replace as necessary.
Also, inspect your radiator for cracks & punctures.
Hope you sort it out quickly. Good luck.
midwestminibikes
03-21-2008 05:52 PM
