97 CBR600F3 clutch installation troubleshoot
Can someone post a link to the most detailed clutch plate installation video for the specific make and year of my bike... Im having trouble and I need something to get around on asap....... Also what way does the judder spring near the pressure plate need to face??? I've put new plates and discs in... Its shifting through the gears but when I put it into first it still rolls.. Helpppp😩😩😩
thanks figured out the judder spring part w some help from google. Can't find any repair manuals online all the links are expired🤷♂️🤦♂️. The bike was going into gears but still moving like it was in neutral while in gear. Im going to try and redo everything see what happens... Maybe w the judder spring in correct position maybe move the pressure plate around a bit see what happens and will get backed to you.. Thanks for the reply brother💯😎😎😎
ya I think that detail with the pressure plate and clutch center locking together is why its was spinning.. I'm going to take apart put together get some instant gasket will let you know how it goes😎😎😎
should the clutch center be up against the clutch plates? Should spinning the clutch center and clutch plate spin the back tire?
