96 cbr600 f3 dies while riding on highway
Old Jun 9, 2011 | 01:12 PM
Shadowfetus's Avatar
Idk how to check my fuel pump but I'm sure I can look up as to how. Im gonna have auto zone test my battery to see what's up, don't have a voltmeter but I may be able to buy one today
Old Jun 9, 2011 | 04:06 PM
STJ2011's Avatar
every good mechanic has a voltmeter, at least 75% of all electrical problems can be diagnosed and fixed with the aid of this. autozone sells one for abotu 20$. i though i had a problem with my r/r becuase my bike would die while riding sometimes. ended up being a bad battery that would hold a charge when it wanted to.
Old Jun 9, 2011 | 08:00 PM
Alright thanks for the advice, once I get paid I'll go grab one. Will update when I see whats up! Thanks for the help everyone hopefully it's only the battery >.<
Old Jun 10, 2011 | 04:46 PM
So no one thinks it's a carb and/or fuel line issue? That's what I was told over the phone by a Honda tech but I'm sure he just wanted me to come in
Old Jun 10, 2011 | 05:09 PM
You said that it ran fine for 20 minutes before experiencing any problems. It's highly unlikely that something got past your fuel filter to cause a problem in your carburetors. It's possible for sure, but unlikely. For the dealer, taking apart your carburetors is a nice cash flow opportunity for them. If it doesn't fix it, oh well you pay anyway.
F3's have 2 common problems. Bad fuel pumps and bad R/R's. I'd be more inclined to go with one of these as opposed to paying someone lots of cash to clean your carburetors.
Old Jun 11, 2011 | 12:57 AM
Alright cool I appreciate all the help guys, fingers crossed it's only the battery lol
Old Jun 16, 2011 | 03:55 PM
Update: Had my old battery tested and they said it had 0% charge(I had just charged it a couple days ago so yeah lol) I bought a new one and she started up just fine, road around a bit and then decided to take a longer test ride down the highway. Same thing happened, it started to stop pulling and eventually just died. Go to start get back up and it just won't turn over again as if the battery is dead. I went to try and push start it but had some trouble getting it into second? Like it would be in N but I couldn't shift down, only up for a little bit till it finally started being normal, but wouldn't turn over. Could it be that R/R you guys were talking about? Like not charging the battery and the bike running purely off the battery which like insta kills it?
Old Jun 16, 2011 | 05:48 PM
If you put a meter on the battery, how much voltage does it show ?
Old Jun 17, 2011 | 01:18 AM
Shadow's Avatar
YUP !
Told you that twice on the first page, son
I will guarantee the bike isn't charging and you need a new reg/rec, or there are bad connections/overheated wiring.(generally associated with a bad reg/rec)
Now go and do what your father tells you hehe
Old Jun 17, 2011 | 10:41 AM
highwaypatrol's Avatar
The simplest way to check if your battery is charging is to start the bike (jump start it if you have jump leads with a good battery away from the bike!). Once the bike is running, switch on your headlight then rev the engine and see if the headlight brightens up and then goes dimmer when you release the throttle. If it doesn't then either the rectifier or alternator is faulty. You can rule out the battery, as you say it is new. When you press the starter button, does the bike turn over very slowly? You should only have to press the starter very briefly and the bike should start if everything in the starter/charging system is ok. Check also the battery earth to frame connection as this will prevent the charge getting to the battery and flatten it in no time, which is what you are experiencing.
