2009 flush mount lights
Old Mar 12, 2011 | 09:39 PM
Popwrestler32's Avatar
Default 2009 flush mount lights
Ordered a set from cbr heaven. I like them, well until i installed them and they didn't work so i spliced them. The only bad thing now. Is they are on all the time. Are there any that work properly with an 09? Searched but didn't find anything.
Old Mar 12, 2011 | 10:42 PM
adrenalnjunky's Avatar
only the 2nd time this week on this page so far :-)
a) guessing 09 600rr?
b) stock front lights are on all the time (running lights) and then blink when the blinker is turned on, rears are only on when blinking. Since the front signals are 3 wire hookups, and the flushmounts probably are only 2 wire, you lose that running light function with the flushmounts. When you say you "spliced" them, I'm guessing you connected the green to the negative on your flushmounts, and you tied the other 2 factory wires (orange, orange/white on one side, blue, blue/white on the other) together. What this does is make all lights illuminated all the time. Disconnect the wires with the white stripes and you'll have blinker only function. To get running lights in the front working without everything else being on - read this thread: https://cbrforum.com/forum/how-mechanical-40/convert-2-wire-signals-3-wire-inputs-84998/
Old Mar 13, 2011 | 01:27 PM
Thanks for the help i will deff try that out! I plugged them up, they did illuminate so i turned the signal on and they didn't flash, i'll try what you said!!
Old Mar 13, 2011 | 01:48 PM
take a pic of your connections @ the front lights - might help us troubleshoot w/ you.
Old Mar 14, 2011 | 04:27 AM
You were right that fixed it. Thanks.
BMACSBACK
May 12, 2011 06:34 PM
jrocken
Nov 6, 2010 10:36 PM
NateDieselF4i
Nov 1, 2010 11:17 PM
Scrat
Feb 9, 2006 04:32 PM
FLYNBYU
Dec 25, 2005 07:54 PM
