2006 CBR600RR OIL FILTER STUCK, HELP
I need some help guys, my oil filter is stuck and will not come off. I have tryed using a oil filter socket to get it off but it wont budge. Anyone have any good ideas to get it off? My socket is starting to round off the filter so the socket is about useless now. Thanks.
RE: 2006 CBR600RR OIL FILTER STUCK, HELP
1. Maybe get a sheet metal screw through the Filter wrench (clearance hole) and into the filter (pilot hole) and then turn it (best if they are on the side). Maybe you could get two screws in, that would be better.
2. Clean both good and JB weld one to the other.
Screw driver works too, but I dont know how much room there is. Also don't get too close to the flange.
I suggest every one who does there own oil changes to buy this.
http://www.lislecorp.com/tool_detail.cfm?detail=1224
Ive had filters stuck on like you wouldnt believe when a screwdriver went thru and just almost cut the filter in 2. Then i used this and its great.
also try getting a leather belt and wrapping it around the filter...then using your bare hands to twist it off...some people also think you can wrap the belt tight enough to where it will make its own torque so you can just pull down on the belt...remember lefty loosey!
ORIGINAL: bluej511
ORIGINAL: marc0011
Hammer a screw driver through it and turn left, make sure it's long though. You'll want the leverage.
You suggest this, he's going to end up putting a hole right through the filter and into the oil cooler.
Use a band wrench or a filter wrench.
