2006 CBR600RR OIL FILTER STUCK, HELP
Old Jan 19, 2008 | 01:26 AM
waynecbr600rr's Avatar
Default 2006 CBR600RR OIL FILTER STUCK, HELP
I need some help guys, my oil filter is stuck and will not come off. I have tryed using a oil filter socket to get it off but it wont budge. Anyone have any good ideas to get it off? My socket is starting to round off the filter so the socket is about useless now. Thanks.
Old Jan 19, 2008 | 02:08 AM
marc0011's Avatar
Default RE: 2006 CBR600RR OIL FILTER STUCK, HELP
Hammera screw driver through it and turn left, make sure it's long though. You'll want the leverage.
Old Jan 19, 2008 | 05:15 AM
fishfryer527's Avatar
1. Maybe get a sheet metal screw through the Filter wrench (clearance hole) and into the filter (pilot hole) and then turn it (best if they are on the side). Maybe you could get two screws in, that would be better.
2. Clean both good and JB weld one to the other.
Screw driver works too, but I dont know how much room there is. Also don't get too close to the flange.
Old Jan 19, 2008 | 08:21 AM
Danyilboon9's Avatar
filter pliers
3 jawed filter remover
or a band wrench
Old Jan 19, 2008 | 08:23 AM
bluej511's Avatar
I suggest every one who does there own oil changes to buy this.
http://www.lislecorp.com/tool_detail.cfm?detail=1224
Ive had filters stuck on like you wouldnt believe when a screwdriver went thru and just almost cut the filter in 2. Then i used this and its great.
Old Jan 19, 2008 | 09:19 AM
VP's Avatar
VP
also try getting a leather belt and wrapping it around the filter...then using your bare hands to twist it off...some people also think you can wrap the belt tight enough to where it will make its own torque so you can just pull down on the belt...remember lefty loosey!
Old Jan 19, 2008 | 09:54 AM
krash's Avatar
ORIGINAL: bluej511
that looks like a great tool. I may just get me one of those. by the looks of it, the more torque you put on it, the tighter the grip it gets on the filter, so very unlikely it will slip like a strap wrench.
Old Jan 19, 2008 | 10:03 AM
bluej511's Avatar
My car uses a m1-110 from mobil and it works GREAT every time. I believe the f4i uses a m1-103 or 108 So it should fit just the same.
Old Jan 19, 2008 | 10:33 AM
knightslugger's Avatar
ORIGINAL: marc0011
Hammer a screw driver through it and turn left, make sure it's long though. You'll want the leverage.
NO NO NO NO NO NO NO
You suggest this, he's going to end up putting a hole right through the filter and into the oil cooler.
Use a band wrench or a filter wrench.
Old Jan 19, 2008 | 10:56 AM
bluej511's Avatar
If your doing an oil change its ok to put a hole thru it. And there is absolutely no way in HELL you will be a hole thru the oil cooler with a screwdriver
