I just bought myself a 2005 CBR600RR, I was wondering what is some routine maintenance I should preform on the bike to make sure its running in top condition, thanks guys.
sparks, oil/oil filter, coolant flush if you dont what kind of care the PO put into it, air filter. maybe clean and lube the chain/sprockets or replace it depending on worn it is
How many miles you have???
Check brake pads...
Check brake fluid...
You prolly gonna want to change the oil in your FORKS.
Set up your suspension properly...
check your spark plugs...
