2004 cbr f4i injector problem
Old 08-21-2009, 12:20 AM
94didonato's Avatar
Default 2004 cbr f4i injector problem
I just replaced my headlight with brand new bright white bulbs(HID knock offs). After doing so the gauge fuse burnt out. I replaced the gauge fuse, but now my injectors won't prime. It turns over and all electronics work but won;t fire because the injectors are not working. I have no idea what to do, please help.
Old 08-21-2009, 09:01 PM
Todd84's Avatar
Your injectors won't prime? Your fuel pump???? Do you hear the whiiirrrrrrr when you turn it on? That is your fuel pump. If not then take it off. Remove the tank the pump is on the botom of the tank. connect it to a battery and see if it works.
Old 08-21-2009, 10:27 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Yeah, I was kinda curious myself as to how you narrowed it down to the injectors. Before you go tearing stuff apart, make sure your kill switch is "ON", and the bike's not in gear with the kickstand down.
Old 08-21-2009, 10:36 PM
skoobydoobie's Avatar
Did you unhook the BAS?
chrsiat954
04-30-2013 01:47 PM
lukethibodeau
04-28-2013 11:05 PM
94didonato
08-21-2009 06:00 AM
edjrwinnt
09-19-2007 09:29 PM
vipkat
06-12-2007 07:27 PM
Quick Reply: 2004 cbr f4i injector problem
