2003 cbr 600rr stalling
Old May 17, 2017 | 11:37 PM
aguila125's Avatar
Default 2003 cbr 600rr stalling
MAYBE SOMEONE COULD TELL ME WHAT'S GOING ON. AFTER TAKING A RIDE FOR ABOUT 10 MILES ON A HOT DAY, I WOULD STOP AND TURN OFF THE ENGINE. AFTER A FEW MINUTES OR SO, THE BIKE WON'T NOT START. I WOULD PRACTICAL PUSH START START IT . DOES ANYBODY KNOW WHAT'S THE PROBLEM????? COULD IT BE MY RECTIFIER OR SOMETHING???? PLS HELP
Old May 19, 2017 | 02:38 AM
bap de la bap's Avatar
Because an electrical system is like a chain the problem could be related to any one of the single links in that chain - I'm not an electrical expert but here is what I've learned so far regarding this type of motorcycle electrical problem:
So the bike starts ok when cold but not hot?: The additional heat generated by the bike after it has reached operating temperature adds extra resistance to the electrical system resulting in reduced current flow - so a dirty or worn electrical connnection that functions when the bike is cold fails when the bike heats up.
Yes it could be related to a failing R/R, a corroded earth connection, worn starter bushes or it could just be something simple like a dirty or corroded starter button contact, battery connectors etc.
Personally I would look at the simple stuff first - take apart the clam that houses the starter button and give the starter contact a clean with contact cleaner - and check out the condition of your battery leads, the conditon of the earth to frame connection, the wiring that goes into the R/R - does the wiring look in good condition - is it badly corroded etc?
If this doesn't solve the problem then we need to look at other components in the electrical system.
Old May 19, 2017 | 11:36 PM
aguila125's Avatar
Thank you bap de la bap, i will check on those things and i'll let you know if it is. Thanx again.
Old May 21, 2017 | 02:31 PM
No problem aguila - I hope it's just a simple fix - like cleaning up the starter contact.
dustinj
Nov 7, 2010 12:17 AM
racerx450r
Apr 8, 2010 10:49 PM
lab4x4
Jun 12, 2008 11:37 AM
lukestad
Apr 26, 2008 11:57 PM
VinnyVino
Apr 25, 2008 01:26 PM
