2001 f4i leaking oil
Old 11-02-2008 | 06:14 PM
CBRcheez's Avatar
Default 2001 f4i leaking oil
hello guys this is my first post so dont rag on me 2 bad if a mess something up
ok well i got this bike 2 weeks ago its got 15,xxx miles on it
got it home and went for a ride (longer then the test ride) and noticed some oil on the right side where the clutch cable ends
so i checked the oil in it and it is high so i took off the right side faring to clean the oil and noticed that there is more i could see just inside there (between the frame and the cover) so i cleaned it off and started it for a wile and none leaked when it was idling it but i took it for a ride and there was more oil again
so i dont know if its because it is over filled and coming out of where the clutch cable ends and goes down into the motor anyone had this happen to them? ( i also tightened 9 or 10 10mm bolts on the cover and the motor to see if that would sop it)
[IMG]local://upfiles/31268/4AAC8AC5E76049BC95F7CB624FABB7EF.jpg[/IMG]
Old 11-03-2008 | 10:32 AM
jonld's Avatar
Default RE: 2001 f4i leaking oil
Download the service manual if you havent already. Get a flash light and look at the CCT(Cam chain tensioner). Good possibility that the plug is missing or gasket is damaged. that would leak oil down on that location when internal pressure builds.
Old 11-10-2008 | 10:36 PM
CBRcheez's Avatar
i have looked at it with a flash light and cant seem to tell where it is coming from
might i have to take the tank off to tell if that is the problem or not?
in the manual it says i have to take the throttle body off to change the CCTL
and i dont want to just jump into doing that if i dont have to
Old 11-10-2008 | 11:50 PM
justasquid's Avatar
theres a possibility that the oil is coming from the fill cap. There is an o-ring on the cap that can become split if tightened too tight. this will allow oil to purge up past the oring. Since you are driving, the air will scatter it all over the place.
A call to the previous owner would be in order. he may have had something apart. If he did, thats a good place to start to make sure what he split apart isnt leaking. A big mistake people make is over tightening bolts. All of the components are aluminum and have been surfaced to fit perfect and require minumum torque to seal. use the suggest torque specs whenever your can. gaskets will become split, component can become warped, this will all lead to oil leakage.
I'm not sure how you are checking your oil, but make sure your doing the proper steps. I've seen a lot of people do it improperly and not get correct readings on oil level.
Old 11-11-2008 | 12:46 AM
TK954RR's Avatar
Jan 2009 ROTM
Where the cable goes in is just a rubber grommet to seal it. Guy could have had the clutch cover off and its dislodged or even torn a bit. Also if your oil is over full, drain a little out.
Old 11-11-2008 | 07:29 AM
Northernfirepower's Avatar
Only leaking at the top? Hmm, have you checked to make sure the cover bolts arent loose? Should be 9ft/lbs of torque (not much at all)
Old 11-11-2008 | 01:27 PM
CBRcheez's Avatar
i checked the bolts and the fill cap it doesent seem to be them
the gasket where the clutch lever goes in will be the next thing i check
thanks guys
Burnthis
07-06-2013 03:49 PM
Mbennett
02-16-2013 09:45 PM
malbojah
03-24-2008 07:22 PM
Lamar Vannoy
01-01-2008 12:22 PM
gmario1000kRR
12-24-2007 08:33 PM
Quick Reply: 2001 f4i leaking oil
