2000 cbr 600 ignition.
i have a new ignition for my cbr that has a red, green, black, and black w/ white stripe i need to wire to bike wiring. Bike wire colors are red, red w/ black stripe, pink, and blue w/ orange stripe. thx
i just cleaned out the carbs, they were very dirty. bike still turns over but no fire. Battery is fully charged. All the electrical, lights etc. are working just fine. fuel pump is working, i have also bypassed the pump and ran fuel straight to carbs. bike still turning over but not firing. Not sure last time bike was running but last full inspection was in 2008. How would i check for spark? ethenol?
well i pretty much looked at a pic on google of a stock ignition and plugged which ones i thought were in the same position on the wiring harness. the lights and all the electrical still work tho? i just didnt wanna switch them up and blow something electrical. how should i check to see if they are plugged into the right place on the wiring harness?
i measured the voltage at the wiring harness from the ignition. 2 wires are at 12v and the other two are at almost 0. shouldnt 3 of the wired read 12v and the pink wire that goes to ecu read a lower voltage?
