2000 cbr 600 ignition.
Old Feb 13, 2013 | 04:33 PM
Pat24's Avatar
Default 2000 cbr 600 ignition.
i have a new ignition for my cbr that has a red, green, black, and black w/ white stripe i need to wire to bike wiring. Bike wire colors are red, red w/ black stripe, pink, and blue w/ orange stripe. thx
Old Feb 13, 2013 | 06:51 PM
Pat24's Avatar
Default Done.
i have fixed the ignition. bike sounds like it is ready to start but still wont start. help?
Old Feb 13, 2013 | 10:40 PM
Are you getting a spark ? Are you getting any fuel ? How well charged is the battery ? What's the history on the bike ? When was the last time it ran ?
Old Feb 14, 2013 | 08:43 PM
Pat24's Avatar
i just cleaned out the carbs, they were very dirty. bike still turns over but no fire. Battery is fully charged. All the electrical, lights etc. are working just fine. fuel pump is working, i have also bypassed the pump and ran fuel straight to carbs. bike still turning over but not firing. Not sure last time bike was running but last full inspection was in 2008. How would i check for spark? ethenol?
Old Feb 15, 2013 | 11:01 AM
CJardine's Avatar
Track junkie & modaholic
What did you wire the pink wire too. 99% when replacing the ignition with these bikes its the pink wire.
Old Feb 15, 2013 | 12:15 PM
Halzinky's Avatar
Let me know what you find out with this... I have a strange feeling my bike is going through same issue
Old Feb 15, 2013 | 07:29 PM
Pat24's Avatar
well i pretty much looked at a pic on google of a stock ignition and plugged which ones i thought were in the same position on the wiring harness. the lights and all the electrical still work tho? i just didnt wanna switch them up and blow something electrical. how should i check to see if they are plugged into the right place on the wiring harness?
Old Feb 16, 2013 | 09:49 AM
CJardine's Avatar
Use a multimeter and measure the current of the pink wire at the ecu, it needs to read approx. 9.3v. That is the anti theft wire telling the bike weather or not its being hot wired.
Old Feb 17, 2013 | 02:40 PM
Pat24's Avatar
i measured the voltage at the wiring harness from the ignition. 2 wires are at 12v and the other two are at almost 0. shouldnt 3 of the wired read 12v and the pink wire that goes to ecu read a lower voltage?
2WheelChillen
Mar 2, 2011 01:07 PM
BigDaddyHonda
Aug 31, 2010 11:15 AM
l0st1
Oct 5, 2009 01:20 PM
tutman6
May 1, 2008 08:54 PM
