2 cylinders?
I have a 900rr and it runs like crap... i've done the following:
Changed Plugs
Cleaned Carbs (Chem B12)
Changed fuel diaphram
Tested the petcock
drained the fuel, put new fuel
Tried Seafoam in the fuel tank
Changed coil for 2/3 (the one on the left) and verified the wiring.
Tested spark and am getting spark on 2/3
cleaned out subair filter
bottom line, only 1 and 4 are firing (because the headers are hot after it runs). 2 and 3 are not hot... i've messed with the fuel mixture screws with no success... still the same thing.. im lost...
Any suggestions are appreciated.. attached is the latest video of how she sounds...
Changed Plugs
Tested the petcock
Not sure how easy/hard it is to get at your float bowls, but after switching on the fuel drop all float bowls from the carbs and look at the level of fuel in them. They should all be the same. If 2 and 3 are low, that is probably the problem. If the levels are the same and all spark plugs fire (lay them on top of the cylinder head and check them for a spark as you crank the engine) then obviously fuel isn't getting to No 2 and 3 cylinders. You'll have to remove all four carbs, strip them down and clean them out thoroughly as it sounds like you have a blockage somewhere. It doesn't take much to block the tiny holes in the jets etc and please don't go poking any wire through the holes. Try getting access to compressed air to do the job. Wish you all the best in solving it!
Changed Plugs
Tested the petcock
Changed Plugs
Tested the petcock
Thanks, yeah I am getting good spark.. so i think it has to do with fuel... i am able to access the float bowls and unscrewed the drain underneath 2 and 3 and fuel is there.. but i don't know how much is in each compared to 1 and 4...
think it could be a fuel screw issue? carb sync?
