1987 Honda Hurricane 600 fuel pump not priming
Fuel pump is not priming, relay doesn't click. Have 11.7 volts on the black wire and yellow and blue wire at fully charged 13 volt battery, pump spins when jumped.
I have been working on it the past few days, can't find where the other 1.3 volts are going besides the fuse box, I cleaned all the contacts on the killswitch and starter button, I'm starting to suspect the ignition since it is a aftermarket ignition installed by previous owner and all aftermarket ignitions are missing the yellow and black wire that says PA.
What do you mean by “besides the fuse box”?
