Fuel Pump of Relay Problem
Old Mar 5, 2024 | 01:48 AM
cata2122's Avatar
Default Fuel Pump of Relay Problem
Hello, I have a problem with the f3 from 97. I start the engine, the pump sends fuel to the carburetor, I leave it at idle and it runs out of fuel, and the pump only starts after I start the motorcycle again. Do you have any ideas?
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAABDUlEQVR4AYXRgUZDYRjH4TegFTKgpEqiFJgoWAoME QGBgBboChaaAKxLKAhAhQqAdAmpBIQolkCFqp2nITvNKXuA7+/Hhzey5OWjE4Nq3rzY1f9/NGHPB549492+8Ww060iCS2XdctZdI3GsECmb+HJoIX6x6EgDm+ lURTH+YB7V9nAqE5WNme4YKuOiY6iMe6PaQxUUIuTbswgFVNJw A8sO3Bn6yR6bWZMSNtJwDtuWfHpQxaPx9C9zadil7jrCigbq6U XceNIVKTWUIqypm2ytJdTiNyNeXclF6GttOVfeDEc7qzjR23r3 OMFqZKng1kw0mXGLrfibHTScOZWgGv9TdC6ROFeMTgwYiIxvJz MRWQbeGZUAAAAASUVORK5CYII=[/img]
Old Mar 17, 2024 | 05:49 PM
kylehasyourfrenchtoast's Avatar
I don’t understand. The pump runs out of fuel? That would be no fuel to the pump. The pump stops pumping fuel that would be the fuel pump. Caltric sells a fuel pump for $19 and works great.
Old Mar 17, 2024 | 06:13 PM
dannoxyz's Avatar
That is correct behavior. Pump only runs until float-bowls are filled, then stops. Pump relay is triggered by ignition-pulses from ignitor. So it only runs pump when engine is spinning.
Test and measure trigger wire between ignitor and pump relay to ensure it’s not broken.
Old Mar 26, 2024 | 12:34 AM
cata2122's Avatar
what color is that wire? black and yellow ?
Old Mar 26, 2024 | 06:25 PM
dannoxyz's Avatar
Here’s how fuel pump relay is wired:
blk/wht = battery power +13v full-time when key ON
blu/yel = grounding pulses from ICM (shared with ignition coil 2-3)
blk/blu = power pulses to fuel-pump
The grounding pulses from ICM would measure full-power most of time. With short pulses to ground to trigger ignition-coil and fuel-pump relay. Looks like this on oscilloscope.
Can also use solenoid-light to check for pulses. And on fuel-pump relay output to pump as well.
Old Mar 28, 2024 | 04:28 AM
cata2122's Avatar
So i need to track blu/yel = grounding pulses from ICM (shared with ignition coil 2-3)
Old Mar 28, 2024 | 07:52 AM
cata2122's Avatar
i check all wire from relay and it s all ok...
Old Mar 28, 2024 | 09:54 AM
dannoxyz's Avatar
Yeah, start with that wire from ICM.
Make sure it reaches coil
Along way it splits off to fuel-pump relay.
Measure its resistance end-to-end between ICM and pump relay to make sure it’s not broken.
Verify pulse signal at fuel pump trigger input and output. Pulse signal to pump may be large enough to pick up with LED test-light. Use solenoid test-light to be sure.
Connella08
Jan 27, 2025 06:25 AM
americobap
Sep 5, 2021 09:17 PM
tonyhaas28
Jul 25, 2011 02:12 AM
mitchedwards81
Dec 9, 2008 12:21 AM
frankinbarnes
Mar 20, 2007 11:56 AM
