100W Bulbs
Old Oct 19, 2006 | 07:56 PM
mikequinn's Avatar
Default RE: 100W Bulbs
Even with the mod the heat from 100w bulb will melt the wiring and cause a short, it will also melt the multi plug too, its not designed for that type of heat.
Old Oct 20, 2006 | 02:21 AM
Ocelaris's Avatar
When you use a relay, the power goes through new wires that you run straight from the battery, fused. So the power going through the stock wiring is only enough to pull the coil down inside the relay, which takes maybe 1 watt. Your stock wiring is safe because you are only using it for a signal.
If you get aftermarket sockets, with 16 or 14 gauge wire, you should not have a problem with them melting. I have made harnesses specifically because a customer kept melting his sockets, and he has not had a problem since. You don't have to make my word for it, but there are aftermarket harnesses meant for that sort of thing, especially off roading.
The whole point is that with HIDs, you use less power (only 35watts) and get 3 times the brightness... the up front cost is more, but it's totally worth it.
Old Jan 22, 2007 | 11:59 AM
alexr40's Avatar
I have been running H7 100W for 9 months by now. Not at problem
I just ordered another one.
Old Jan 22, 2007 | 04:40 PM
Tahoe SC's Avatar
give it a little more time...and you'll see.
as far as bulbs...you can bust silverstars but not the domestic ones from sylvania...but the overseas OSRAM types...those are very nice...or get the philips vision plus +50.
Old Jan 22, 2007 | 05:03 PM
D2VW14_20's Avatar
Yeah, I took them out of the bike about 5 days after I put them in. The lenses get super hot and just wanted to be proactive. I have some 55 HID look a likes in there now and are awesome ,,,,, I forgot abou this subject, it was a while ago
Old Jan 23, 2007 | 12:51 AM
jorge13's Avatar
I´m using the Philips vision plus + 50 and are really excellent !
Mark Dowsett Bugsy
Jan 24, 2015 06:48 AM
tip38
Mar 9, 2011 11:48 PM
Grafx
Aug 3, 2010 05:53 PM
new06f4iowner
Feb 3, 2010 10:08 AM
Wildcat
May 2, 2007 01:27 AM
