100F Wiring
Old Jun 24, 2012 | 05:38 AM
godoyi1452's Avatar
Default 100F Wiring
Can anyone assist with a decent wiring diagram for a 2001 1000F?
I have replaced the fan with a a similar , but not original unit, and cannot get it to switch off. Negs are bridged and Pos. direct to plug.
This is a project bike.
Old Jun 24, 2012 | 02:20 PM
highwaypatrol's Avatar
could it be that the fan switch is faulty, keeping the fan going? Only a thought, but try activating the fan with a battery direct to the terminals on the bench and then remove the wires. If the fan then stops, it looks like the fan switch is the problem.
Old Jun 24, 2012 | 02:28 PM
MadHattr059's Avatar
Most thermo-couples/thermosisters ground (-) to frame when turning the fan on.
Everything runs hot (+), seriel from the fan.
You should be running the hot to the fan and then a bridge/jumper from the fan to
the thermo-couple.
Won't swear to it on your bike, but that is the typical arrangement.
Hope that helps, Ern
Old Jun 25, 2012 | 09:09 AM
godoyi1452's Avatar
Default 1000F wiring
Thanks Em
That's pretty much how I had it. Runs direct from plug on wiring harness when IGN switched on. Bridge to thermo-switch makes no diff connected or not. A head scratcher.
sonicbluerider
CBR1000F For Sale / Found
Mar 19, 2010 05:39 PM
Stewart
Feb 10, 2008 12:27 PM
oadamo
Dec 18, 2007 11:57 AM
mastice
Nov 26, 2005 04:37 AM
