09 Cbr600rr fuel pump not priming and relay not clicking
Old May 31, 2018 | 07:14 AM
Lukedive97's Avatar
Default 09 Cbr600rr fuel pump not priming and relay not clicking
Hi Guys, my 09 Cbr600rr was in an accident so it doesn’t have a front end at the moment, the gauges light up and the bike turns over but the fuel pump doesn’t prime. Iv seen threads where people say the relays are clicking but mine are not.
Old May 31, 2018 | 08:16 AM
CaBaRet's Avatar
Is your Headlight harness connected
Old May 31, 2018 | 09:39 AM
Lukedive97's Avatar
Default Cbr600rr
Yes but the lights are not, I still have to order them.
Old May 31, 2018 | 09:51 AM
CaBaRet's Avatar
What i was thinking about is the BAS which is part of that harness
Old May 31, 2018 | 09:54 AM
Lukedive97's Avatar
Default Cbr600rr
Ohh, is that infront of the air filter? And how do I check it?
Old May 31, 2018 | 10:05 AM
CaBaRet's Avatar
at this stage all you have to do is by-pass it,it has a 3 pin connector going to it, it has a White wire ,a Green wire and a Red wire with a trace in it , connect a jumper wire to the two outer wires on the connector (Green and Red wires ) that's it by-passed
Old Jun 1, 2018 | 03:30 AM
Lukedive97's Avatar
Default Cbr600rr
Okay I bypassed it and the relays click and the fi and engine light come on now also when I turn the ignition, but if I listen closely to the tank I can hear a slight rapid click coming from the fuel pump
Old Jun 1, 2018 | 03:46 AM
CaBaRet's Avatar
Daft question but is there any fuel in the tank, and does the pump prime, would also check for spark now
Old Jun 1, 2018 | 03:59 AM
Lukedive97's Avatar
Default Cbr600rr
Yes there is some new fuel in the tank and no the only noise it makes is that faint ticking noise. Where would I check for spark?
Old Jun 1, 2018 | 04:15 AM
CaBaRet's Avatar
You need to get the spark plug out , put it back in the coil stick and earth it on the frame , keeping your hands away from the plug , turn the engine over and see if you get a spark at the electrode, have you got the workshop manual
