07 CBR600RR Neutral light Issue
I am having issues with the neutral light on my dash when the gear is in Neutral my light will not turn on. Its a 07 CBR 600RR. Any help is greatly appreciated.
Thanks,
AG
Thanks,
AG
You'll need a manual with a wiring diagram.
If the light uses a bulb, you should check that first. If the bulb is good or there isn't one, check the wiring.
If the connections are corroded a squirt of contact cleaner along will unplugging and plugging in a few times will usually do the trick.
Although unlikely, switch could be at fault. Neutral switches are usually screwed to the side of the transmission and have a little plunger that lines up with a bump on a gear inside. When the bump lines up with the plunger the switch turns the light on. Don't change this unless you've eliminated everything else.
