061000rr radaitor fluid onthe fairing&clutch cover
i have a 06 1000rr with 4000 mi on it and i noticed alot of over flow
its not overheating yet but there is a lot of radiator fluid coming out
of the hose and its coming out the vent where the radiator fan vents on the
side fairing its all over the clutch cover after 2 hours of riding..
what could the problem be??[:@][:@][:@]
Could be the Thermostat, Pressure cap, But sounds like you have a blockage in the radiator pipes, causing the build up of pressure. Supprised it's not coming out pass the cap. Any bubbling in the fluid reservoir?
(Just to make sure, you haven't had a stone punch it? Sometimes this is enough to crimp the flow through the pipes)
Either way, get it looked at. I wouldn't be riding it to far, as Dirty Harry would say, "When you run outta coolant, your **** outta luck".
Bordo
Sep 21, 2012 07:33 PM
