06 F4i no power when key on besides when kill switch is off and pressing start button
I have a 2006 f4i and I went to ride it to storage yesterday and it started normally, I went inside for a second and when I came out the cluster was sweeping back and forth and the display screen was flickering and going crazy. So I shut it off and it wouldn’t turn back on at all, I took apart the start button and cleaned the connections. But now it only gets power to the screen when the key is on but the kill switch is in the off position and you press the start button , if I switch it to run it turns everything off again. I have checked the battery is fine even tried hooking a jumper up and doesn’t change anything, and the main fuse is not blown. I’m at a loss, any help would be appreciated .
