06 cbr600 f4i fuel pump not priming
Old Mar 21, 2019 | 03:40 PM
06cbr600f4i's Avatar
Default 06 cbr600 f4i fuel pump not priming
I changed my blinkers to flush mounts and ever since, my fuel pump wont prime and my bike will turn over and over and over. I have a empty connector and wondering if that’s the issue. Cant see anywhere that plug would go? Bike turned over just fine before all of this. And yes my headlights work
Old Mar 21, 2019 | 03:50 PM
CaBaRet's Avatar
Hi the only 3 pin plug I know at the front end belongs to the BAS, if thats disconnected your bike wont start
Old Mar 21, 2019 | 04:23 PM
it does have the two little relays on the front that bolt to the back of the headlight housing, and one of them has that same exact connection. But I don’t know where it would go I don’t see any female connectors.
Old Mar 21, 2019 | 04:39 PM
CaBaRet's Avatar
Old Mar 21, 2019 | 04:45 PM
Default I c
my bike doesnt even have a BAS on it :/, it was probably bypassed by the last owner
Old Mar 21, 2019 | 06:44 PM
74demon's Avatar
Then you need to make sure it's still bypassed.
Old Mar 22, 2019 | 02:43 AM
CaBaRet's Avatar
As Demon say's bypass the switch, there are 3 wires , Green , White and Red/White, connect the Green and the Red/White with a piece of jumper wire , on the harness side and your bypassed
Old Mar 23, 2019 | 01:12 PM
so I connect the two outside wires on the 3 pin plug together?
Old Mar 23, 2019 | 01:15 PM
CaBaRet's Avatar
Thats right, 2 outside wires
Old Mar 23, 2019 | 01:36 PM
so just to be clear, all i’m doing is splicing those two wires together
