03 honda cbr954rr fuel pump wont prime
Old Aug 6, 2016 | 01:22 PM
Tai954's Avatar
Default 03 honda cbr954rr fuel pump wont prime
Hi to everyone it has been a while i have a problem with my 03 honda cbr954rr i rebuilt the engine & the bike started once after that i wasnt getting any fuel pump priming the tip over sensor was faulty i replaced it the ignition switch was faulty i replaced it & still i wont get no fuel pump prime & no spark the ecm is good i got it checked cant seem to find the problem can sum one please give me sum help thanks alot my fellow riders.
Old Aug 6, 2016 | 02:16 PM
74demon's Avatar
Did you check the FI fuse?
Old Aug 6, 2016 | 06:16 PM
Tai954's Avatar
I checked all the fuses & they are all good so am still stumped as too why still no fuel pump or spark
Old Aug 7, 2016 | 10:32 AM
74demon's Avatar
Where did you get the ignition switch from?
Aftermarket ones tend to not work correctly. Make sure you have 9v at the pink wire from the switch.
Also, how long did it run for and how did I run?
Make sure everything is still plugged in.
Old Aug 7, 2016 | 11:18 AM
Tai954's Avatar
I got the ignition switch from partzilla.com. I am getting between 9.5 & 8.5vlts but it doesnt go below 8.5volts or it doesnt go above 9.5vlts on the pink wire i guess that voltage is ok anything lower or higher i guess the diode is fried. When i first rebuilt the bike it ran for 15mins good so i stopped the bike & went for more gas when i came back & filled the gas tank & tried to start it but no fuel pump prime unless i put direct 12vlts to it.
Old Aug 9, 2016 | 07:34 PM
Tai954's Avatar
Heyyyyy there 74demon i found the problem it was the servo motor the wires were jacked so thats y i wasnt getting any fuel pump prime or spark i unplugged the servo motor & the fuel pump primed & i got spark so too any one else who encounters a no spark or fuel prime on there cbr do all ur major checks & please dont forget to check your servo motor please thanks again 74demon have a gr8 one fellow riders & keep revving your hearts✌.
Old Aug 15, 2016 | 03:43 AM
Tai954's Avatar
Default Spark problem
Hello fellow riders my friends cbr is only getting spark on #1 & #2 coils but no spark on #3 & #4 what could that problem be any info would be very gr8 thanks alot
Old Aug 15, 2016 | 05:14 AM
74demon's Avatar
Switch the coils around and see if the problem moves with them.
Old Aug 15, 2016 | 06:39 AM
Tai954's Avatar
I switched them around & got spark on # 3 coil but only for a short time but still no spark on # 4 so i will check the power wires that are going to #3 & #4 coils & see if they have any breakage in the wires & repost with my findings
Old Aug 16, 2016 | 10:43 AM
Jaybird180's Avatar
Where is this located?
