03 cbr 600rr fuel pump won't prime
Old May 27, 2014 | 10:17 AM
JAY4151's Avatar
Default 03 cbr 600rr fuel pump won't prime
Guys,
I have been working on this bike for a few days and am at wits end. I am getting power up to the connector for the fuel pump, but pump won't prime. When I test the pump by straight wiring it, it works...but as soon as I connect it to the bike harness, I get nothing. Any thoughts? Sorry if this has been previously discussed.
Old May 28, 2014 | 07:24 AM
Conrice's Avatar
You've tested the pump directly and know it works, and you get power to the plug - but when you plug it into the harness, it doesn't.
Then it's at the plug. Check it for a good connection.
Old Jul 14, 2014 | 12:17 AM
A320guy's Avatar
New Member
Had same funny problem on my 929.The wires that are potted in place and run through the pump assembly from the outside to the pump had a bad connection which you can't access to repair. The first time it happened,I replaced just the pump,then 2 months later thought it was bad and got a replacement pump,which didn't do jack! Annnnd,of course,the fuel low level sensor didn't work on the new unit,but I'll get to that some other time.
Old Mar 6, 2016 | 05:17 PM
Sergeio Wynn's Avatar
Did u figure it out I'm having the same problem on my 03 Honda cbr600rr
Cotswold_CBR
Mar 21, 2020 04:01 PM
Ls1Mx5
Jan 5, 2014 04:01 PM
adamw89_2000
Jul 8, 2010 05:15 PM
vangill
Mar 11, 2010 10:37 AM
Dan Da Man
Jun 14, 2008 06:22 PM
