03 954 rpm flutter under load
All right peeps.. looking for some help here I have a 2003 Honda 954 under a hard load second third gear Don't know about 4th. When you accelerate hard it seems like the clutch is slipping around 9,000 RPMs so I replaced the clutch still having the issue I would say it almost still feels like the clutch is slipping everything is adjusted properly... The problem I am noticing and the best way to explain it would be if you were to pull the clutch in and out rapidly three or four times you can watch the RPMs drop from 9000 to 8,000 at least three times and then everything seems fine after that... If you bring it up to 9,000 RPM slowly nothing happens everything seems fine only seems like it's under a hard load... Like I said I had replaced the clutch already Old one did not look bad replaced it anyways still having the same issue... My next thought was maybe the chain jumping up on the sprocket but all that looks good as well adjusted properly no fuel injection light no malfunction light nothing when this happens... Right now I am at a loss please help... Checked all vacuum hoses as well pulled fuel pressure regulator hose off while priming no leaks..
burbleburble
Oct 3, 2013 08:29 PM
