02 F4I replacement V/R oem or aftermarket??
I can't speak about on your particular model. I can say that the Regulator/Rectifier on the F3's and F2's are prone to failure. They overheat and go bad regularly. Many users, including myself have installed R/R's from GSX/R's. They have larger heat sinks, are easy to modify for installing, and are readily available off ebay for under $50. You should run your question by the F4 forums, or at least do a search there to see.
Here's the difference
Before with OEM.
After with GSX/R
Before with OEM.
After with GSX/R
I've documented the following in the F4 section several times...
Honda upgraded to a finned version that supersedes the old flat version that was prone to overheating & failure. The new finned version factory Honda R/R is a nice R/R & is a direct plug-in replacement.
For REFERENCE:
For REFERENCE:
- Old original model part no. SH633-12 (should no longer be available).
- New finned model part no. 31600-MV4-010.
siCk f 4 i
F4i - Wanted
07-25-2011 04:26 AM
00, 02, 31600mv4010, 600, aftermarket, cbr, connector, f4, f4i, forum, honda, oem, overheating, regulator, sh63312
